wits-zach
May 27, 2019Follower
XS748T Power Off/Reboot/Power Cycle Procedure?
Hello, What is the proper procedure for safely powering down or rebooting the XS748T? I do not see a power button, and I looked for but did not find a way to power off the device in the web UI. ...
- May 27, 2019
For reboot (e.g. after changing the other Flash partition active for the next boot):
Maintenance -> Reset -> Device Reboot
For shutdown .... these devices are intended to run 24*7*36 ... so just pull the plug.
schumaku
May 27, 2019Guru - Experienced User
