Toonlord
Apr 26, 2023Aspirant
WAC 104 enabling 5GHz wireless repeating
I have the 2.4 repeating enabled but for some reason the check box to enable 5GHz is grayed out. Any ideas on how to fix that or is it not capable of that.
- Jul 18, 2023
The 5 GHz radio is configured to auto channel? Wireless repeating can't be enabled with auto channel.
schumaku
Jul 18, 2023Guru - Experienced User
