Patreek's avatar
Patreek
Tutor
Feb 09, 2019
Wireless Repeater Nighthawk R6700v2
According to many sources on the forums, my R6700v2 is capable of acting as a wireless repeater.  I have seen a literal ton of advanced features for the router and am impressed, but I see nothing about using the router as a repeater.  This is one of the most basic uses for a wireless router so I am sure I am doing something wrong.
I have tried the following:
https://kb.netgear.com/24108/How-do-I-configure-my-Nighthawk-router-as-a-wireless-repeater
I don't see  ADVANCED > Advanced Setup > Wireless Repeating in the advanced setup menu.
  • Patreek's avatar
    Patreek
    Feb 10, 2019
    I'm going to return both units and avoid Netgear all together.  I honestly can't comprehend why they would include so many features I do not need on a wireless router, but not wireless repeating.
  • > According to many sources on the forums, [...]
       Thanks for the helpful links.
    > [...] my R6700v2 is capable of acting as a wireless repeater. [...]
       You couldn't prove it by the User Manual.  Visit
    http://netgear.com/support , put in your model number, and look for
    Documentation.  Get the User Manual.  Look for "repeat".  For a good
    time, try that again for the "R7000".
    > [...] This is one of the most basic uses for a wireless router [...]
       Not for this one?
    > [...] so I am sure I am doing something wrong.
       Trusting Netgear product documentation?
       Trust no one, I always say.  (The firmware could have changed, too.)
    > [...] I have seen a literal ton of advanced features for the router
       You must be using some _new_ meaning of "literal".
          https://www.youtube.com/watch?v=4-ImRMJX68s
    • Patreek's avatar
      Patreek
      Tutor
      This was posted by a forum mod here:
      https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Netgear-R7000-not-working-as-repeater/m-p/1446290/highlight/true#M73586
      Yes, it seems to have support for VPN, DynamicDNS and wireless bridging but not repeating a signal... weird.
      Unless you are a C programmer I don't see the point of using those ironic underscores like Linus Torvalds.  It's like you're trying to let the world know you discovered PHP magic constants or Python's dunder methods.
      • antinode's avatar
        antinode
        Guru
        > This was posted by a forum mod here: [...]
           Perhaps it was true then. Firmware "updates" are not called
        "upgrades" for a reason.
        > Unless you are a C programmer [...]
           I do write some C, but I don't see its relevance.  Your analysis of
        simple, low-effort underlining is too deep for me.  "ironic"?  I was
        trying for "emphatic".
