TexasMark
Jan 08, 2024Aspirant
WAC104 dropping connections disassociated deauthenticated and DHCP issues
Sort of an old thread, but I think it may be similar to an issue I have been having with my WAC104. The first issue (that I noted in another thread) is that the list of connected wireless devices i...
TexasMark
I switched to DHCP and it did not help with it showing the connected devices.
In my other thread, I mentioned only a couple of devices showing as connected. I seemed like if i disconnected the LG Android phones, the other devices would show up. However, I now have like 10 wireless clients, but the UI will only show 4 wireless devices max (no Android phones connected).
In my post above, I was asking if the WAC104 may have had it's own DHCP server, but I see it does not.
You said:
"The only point I am able to follow you is is the fact that the WAC104 does indeed offer a Web UI control for rebooting/restarting the AP."
Are you saying there is a reboot function in the UI? If so, where? I can't find it anywhere. I'm on V1.0.4.21
schumaku
Jan 08, 2024Guru - Experienced User
This should have been typed as "The only point I am able to follow you is is the fact that the WAC104 does indeed -not- offer a Web UI control for rebooting/restarting the AP." ... sorry for the confusion.
Greeting to the Longhorns from the land of Brown Swiss. Appears I have to work again on my TOFEL test 8-)
- TexasMarkJan 08, 2024Aspirant
I think I found the reason for the missing attached wireless devices (sort of). Just like with those LG cell phones from my other thread, I found one wifi device (an energy monitor) that once it connects, it causes the list of attached devices to de-populate (the devices are still connected though and still work). So something in the WAC104 just does not like certain wireless devices for whatever reason. Now I need to see if that device was also somehow causing my IP conflicts.
