JMcGee88
Mar 22, 2021Aspirant
WAC104 dropping connections disassociated deauthenticated and DHCP issues (possibly solved)
Sorry for a long post, and if this issue has been raised and answered. But I've had wireless connection issues on a WAC104, and believe I found the cause.
I have somewhat complex home network which includes a server, two netgear managed switches, an AT&T 2-Wire residential gateway, and a WAC104 access point. I have been experincing issues with dropped wireless connections, failures to connect, WAC104 logs showing frequent entries for "disassociated", "deauthenticated", and "WLAN access rejected: incorrect security". The WAC104 "Attached Devices" would only list a single device when we have multiple wireless devices.
I believe the issue was caused by my using a static IP address for the WAC104. Given the complexity of my network I prefer to use static IP adresses for certain devices, my server, switches, printers, televisions, and the WAC104. But all other devices were DHCP assigned from a range established on the 2-Wire gateway.
We have been expreiencing frequent disconnects of wifi devices, and failures to reconnect. I enabled debugging on some android devices, and found log entries with "NETWORK_SELECTION_DISABLED_DHCP_FAILURE"
It seems that by having the WAC104 configured with a static IP address it was breaking DHCP assignments for devices that were connecting through it. I reconfigured the WAC104 to use DHCP for its own address and immediately saw an improvement. The UI on the WAC104 now shows all connected wireless devices and so far, (2 hours time passed), no connections have dropped.
I would not have expected that the use of a static address for the WAC104 would have prevented the wireless clients from using DHCP from the 2-Wire gateway. But this seems to be the case.
> [...] my using a static IP address for the WAC104. [...]
Did you leave this (unspecified) "a static IP address" in the DHCP
pool on your main router?> I would not have expected [...]
Nor would I, if you did it properly.
- JMcGee88Aspirant
On the main router I had designated the free pool for dhcp as a range from xxx.xxx.xxx.100 to xxx.xxx.xxx.249.
I used the range from .250 to .254 as static addresses for the main router, the two switches, and the WAC104. My server and other fixed address devices are statically set from addreses below .100.
My theory now is that the issue is actually within the AT&T 2-Wire gateway/router. But it's puzzling... wireless devices connecting through the WAC104 were getting dchp assigned addresses from the free pool; but just with erratic connection issues and the errors mentioned in my post. I've also run a wireshark capture, and see a lot of ARP packets repeating from the 2-Wire.
But wireless connections have been solid since I changed the WAC104 to use DHCP. I also set a rule in the 2-Wire so that the mac of the WAC104 will get assigned address .249, (so at least I'll know where to find it without looking).
> On the main router [...]
That all sounds plausible to me. The only other typical DHCP error
is having multiple (uncoordinated) DHCP servers, which can cause
confusion.> But wireless connections have been solid since I changed the WAC104 to
> use DHCP. [...]That does change its IP address. Any chance that it was colliding
with some other device on its original/static address? Otherwise, I may
be out of ideas.Shrink the pool a little more, and give the WAC104 a static address
of ".249"? Is the problem "static", or the particular address?
