TexasMark
Jan 08, 2024Aspirant
WAC104 dropping connections disassociated deauthenticated and DHCP issues
Sort of an old thread, but I think it may be similar to an issue I have been having with my WAC104. The first issue (that I noted in another thread) is that the list of connected wireless devices is missing about half of the devices that are actually connected. I thought I had that issue narrowed down to certain Android devices that were connected, but that issue persists. The other issue it that with my main router (WNDR4500v2 ) that is the only DHCP server, I seem to be getting IP conflicts. Note: I too have the WAC104 set with a static IP. The IP conflict seems to happen with the devices connected to the WAC104. Not sure what is going on. I know the WAC104 is passing along the DHCP requests, but somehow either the renewal requests or something else is going on that causes the WNDR4500v2 to reissue the IP to another device while the first device is still connected.
Question for anyone who is using DHCP on the WAC104.
Lets say my WNDR4500v2 is doling out 192.168.3.100 to 192.168.3.255 with it's DHCP server. If I switch the WAC104 to use DHCP, what range does the WAC104 dole out, or does switching to DHCP just mean it gets it's own address from the WNDR4500v2 and continues to just pass DHCP requests from it's connected devices to the WNDR4500v2?
In your old post, you talked about only two Connected Wireless devices becoming listed:
My test clients remains associated rock solid, despite of a bunch of 802.11ac, 802.11.ax, and WiFi 7 AP using the similar wireless channels - so massively less than ideal conditions, WAC104 v1.0.4.21. UI looks very similar on the current Chrome, on Edge, on Firefox, and on Opera (all on a up2date Windows 10 system).
Hmmm. Not sure what you re talking about here.
Can't see any indications on the WAC104 current firmware with Web UI (v1.0.4.21), neither in the WAC104 Data Sheet, nor in the WAC104 User Manual for offering a DHCP server service or the like.
This is regardless if letting the LAN DHCP (noting fancy, a MK63 system, with the WAC104 connected to a satellite) assign the WAC104 IP address by DHCP, having a reserved MAC-IP address, or configuring the WAC104 with a static IP config.
No idea what could cause the issues you mention. Probably there are more routers involved, probably there is a loop on the WAC104 LAN somehow not detected and blocked (no idea if there is such a function....).
The only point I am able to follow you is is the fact that the WAC104 does indeed offer a Web UI control for rebooting/restarting the AP.
-Kurt
- TexasMarkAspirant
I switched to DHCP and it did not help with it showing the connected devices.
In my other thread, I mentioned only a couple of devices showing as connected. I seemed like if i disconnected the LG Android phones, the other devices would show up. However, I now have like 10 wireless clients, but the UI will only show 4 wireless devices max (no Android phones connected).
In my post above, I was asking if the WAC104 may have had it's own DHCP server, but I see it does not.
You said:
"The only point I am able to follow you is is the fact that the WAC104 does indeed offer a Web UI control for rebooting/restarting the AP."
Are you saying there is a reboot function in the UI? If so, where? I can't find it anywhere. I'm on V1.0.4.21
This should have been typed as "The only point I am able to follow you is is the fact that the WAC104 does indeed -not- offer a Web UI control for rebooting/restarting the AP." ... sorry for the confusion.
Greeting to the Longhorns from the land of Brown Swiss. Appears I have to work again on my TOFEL test 8-)
