skinfrakki's avatar
skinfrakki
Follower
Sep 01, 2025
WAC124 Can't Login
I have been trying to login to my WAC124 via 192.168.1.100. It prompts me for my login and then it pops up with the same login screen. How do I fix this?
  • schumaku's avatar
    schumaku
    This could been caused by the unlucky "single sign on" implemented on these earlier Business Essential Access Points. This legacy SSO system is no longer online, so the access will be refused by default!
    Strongly suggested updating to the WAC124 Firmware Version 1.0.4.9 with the removed NETGEAR single sign-on feature.
    Just in case: There might be no other way than disconnecting the WAC124 (and similar) from the Internet, login and update it while direct connected from a PC to the WAC124.
  • plemans's avatar
    Did you try a different browser/device? Are you sure you're using the correct login?
ProSupport for Business
