Tallman's avatar
Jan 10, 2025
WAX204 Wireless Radio Not Turning on After Scheduled Shutoff
I have my WAX204 operating in router mode and have it set to turn off the Wi-Fi radio during the nighttime hours. Every few months or so the radio does not turn on in the morning, so I have to go int...
  • Tallman's avatar
    Tallman
    May 29, 2025
    Hi BrianL​,
    It was a long road that involved lots of emails back and forth with tech support, replacing my modem, and a technician from my ISP coming out, but in the end Netgear did a second RMA because of an issue I was having with the WI-FI radio sometimes not turning on after a forced reboot, requiring the radio to be manually turned on from within the device GUI.  I have had the second replacement now for about a week and a half and have not had any issues.  I must say that even though it was a slow process, all the support agents I worked with were very patient and easy to work with.  Thank you Netgear!
    Carl
ProSupport for Business
