j_pic's avatar
j_pic
Guide
Feb 09, 2016
Can't turn on wireless
Today I updated the firmware on my Nighthawk X6. Since I've done so, it wont transmit a wireless signal. On the Netgear Genie, it says my wirelss is off, but when I click it, it's showing that everything is enabled. Capture.PNG
  • Retired_Member's avatar
    Retired_Member
    Feb 11, 2016
    Just to be sure you're using the power supply that came with the router.  12VDC and 5 amp?
    I have this same router and using same FW and everything is working.
    Did you load a backup to the replacement router?
    Also have you tried the reset with the replacement?
  • 1. save a copy of your config file (Advanced > Administration > Backup Settings)
    2. reset the device to factory default
    3. do not load the config file after reset test first if wireless is working
    • if working load the config file from step 1 then test wireless again
    • j_pic's avatar
      j_pic
      Guide
      ok, i have reset and still dont have wireless, what should i do now?
        Retired_Member
        Did you happen to push the radio off button on router
  • Just hooked up the new router and having the same issue. It's saying that my wifi is turned off but when I check, everything is on.
      Retired_Member
      check that you have a SSID entered for each RADIO
      Post a screen shot of each Wireless  setup screen   BASIC & Advanced
      Clicking the yellow icon RADIO OFF  should bring you to advanced wireless settings
      Enable Wireless Router Radio should be checked
