JT_U
Sep 01, 2026Aspirant
WAX210 Band Steering Made AP hanging
I got a new WAX210 used in the office. Everytime I enabled band steering in the configuration, the AP hanged with red lights blinking. Then I can no longer login to AP unless factory reset. The A...
alextaylorone
Sep 08, 2026Aspirant
Since the AP only hangs when band steering is enabled and recovers after a factory reset, I would lean more toward a firmware/configuration issue than a hardware failure. The fact that the setting is being changed through the WAX Web UI is useful too.
If you can reproduce it consistently, I'd check whether the same thing happens with a freshly reset AP before changing any other settings. That would help narrow down whether band steering itself is triggering the problem or whether it is conflicting with another configuration. It may also be worth checking whether NETGEAR has a newer firmware than 1.1.0.36 for the WAX210.
