AJ08
Oct 19, 2026Tutor
WAX210 Management Password Issue?
What a miserable setup experience I've had with this device. I went through the same process and finally used Password!1 and it finally took it. Hopefully this helps someone else in the future.
AJ08
Oct 21, 2026Tutor
I am a Mac user and the password that it refused to allow me to log in with after I set it had a $, one uppercase letter, three numbers, and three lower case letters.
- schumakuOct 21, 2026Guru - Experienced User
Asking as not owning or operating any WAX210:
You report hat the initial password requirements at day zero are accepting and passing passwords, whenever initially accepted password don't allow the login later on? Reads like a bug to me.
