edgecode
Aug 02, 2026Aspirant
WAX214v2 managment interface onnnly accessible wired
My WAX214v2 is working fine as an AP but I can't log into its managment via wireless. Wired using same IP works. Interestengly, the router shows all clients connected to the AP but not the Ap its...
- Aug 04, 2026
edgecode wrote:
Yes, two VLANs in addition to the default one are set up on the router.
Maybe take a look at page 31 here:
edgecode
I have a similar problem with WAX214v2. The AP is working fine. I can access the setup page if connected by cable to the router. However I cannot access it over WiFi using the same IP. The IP is static, BTW.
