1Coops
Jan 03, 2024Aspirant
WAX220 WIFI Disconnects on Apple devices
Please help, this has been doing my nut in. WAX220 WIFI AP for some reason keeps disconnecting Apple Iphones for a minute frequently and causes calls on facetime to freeze and become unsuitable t...
Jimmy2024
Mar 12, 2024Aspirant
if you disable “auto join” in the apple wifi setting for the specific ssid you will probably find the connection drops and the WiFi actually disconnects. That’s what I found.
with auto join enabled I guess the network drops, you lose access but the WiFi is reconnecting in the background.
schumaku
Mar 12, 2024Guru - Experienced User
Jimmy2024 wrote:
... That’s what I found.
Ask to Join Networks [Off] | [Notify] | [Ask]
Auto-Join Hotspot [Never] | [Ask to Join] | [Automatic]
One of these, and set how?
- May 21, 2023Retired_Member
