NG4B
Jul 05, 2018Aspirant
0x8899 broacasts / Realtek Layer 2 Protocols
Hello,
I have a network admin and reviewing the network traffic on a client network.
They have a NETGEAR ProSafe FS116P v2 switch
The device is constantly broadcasting Realtek Ether-type (0x889...
- Jul 11, 2018
Plenty of small switches (by various vendors btw.) are making use of this (and similar!) methods for detecting network loops -> Realtek Remote Control Protocol - Loop Detect Packet - absolutley nothing wrong with it.
DaneA
Jul 08, 2018NETGEAR Employee Retired
Hi NG4B,
Welcome to the community! :)
As far as I have checked, there is no issue logged for the FS116Pv2 switch as per you have described on your post. Let us isolate the problem. Kindly answer the questions below:
a. What test did you perform wherein you see the Realtek Ether-type (0x8899) frames being broadcast from the FS116Pv2 switch?
b. How is everything connected? It would be best if you post an image or screenshot of your existing network setup.
c. If you disconnect the FS116Pv2 switch from the existing network, are you still seeing Realtek Ether-type (0x8899) frames being broadcast?
DaneA
NETGEAR Community Team
- schumakuJul 11, 2018Guru - Experienced User
- NG4BJul 23, 2018Aspirant
Hello thanks for the reply,
Simple infrastructure small office, Netgear switch, draytek router, fixed ip broadband
I was just doing some packet captures and identified this continuous traffic
although must be part of the intelligence of the switch I was curious if this traffic was due to a mode or scenario
- schumakuJul 23, 2018Guru - Experienced User
No problem, better ask than sorry.
