SteveM58
Nov 16, 2022Aspirant
30 m CAT6 cable length seems too long
I have tried using a UNIFI AP from an unmanaged 108 switch. It works off 1 m lengths of cable. But when attached to about 30m, the AP connects successfully for 30 seconds and then drops and reports...
Kitsap
Nov 16, 2022Master
SteveM58 wrote:I have tried using a UNIFI AP from an unmanaged 108 switch. It works off 1 m lengths of cable. But when attached to about 30m, the AP connects successfully for 30 seconds and then drops and reports it i searching for connection.
Can anyone advise on how to establish connection through the CAT 6 cable
Many Thanks
Steve
A bad cable is always a possibility. Is your 30 m cable a commercially manufactured item?
The Unifi Access Point (UAP) requires Power Over Ethernet (POE) to function. The different UAP models require different levels of power.
I do not know if your un-managed 108 switch supplies sufficient power for your UAP. The power supply could be marginal and work fine with a 1 m cable but not be sufficient to power the UAP over a 30 m length of cable.
Compare the power requirements details for your UAP and compare them to the power supply details for your switch.
SteveM58
I am using professional reel of Cat6. The cable tester signals OK on all 8 strands
- KitsapNov 16, 2022Master
SteveM58 wrote:I am using professional reel of Cat6. The cable tester signals OK on all 8 strands
Do you know the full model designation and generation of your UAP? Something like UAP-Pro (Gen2).
Are you using the POE injector that was supplied with your UAP or a different one? It could still be a power supply issue that shows up when using the different length of Ethernet cables.
I doubt if your cable tester tests for current carrying capability or data transmission. Most likely it only tests for continuity and conductor sequence.
Do you have an intermediate length Ethernet cable you could use for a test?
Unifi has had a number of firmware updates for their UAP line. Are you sure you are giving your UAP sufficient time to go through a firmware update and restart? It could be ten minutes or more. Best done with the short Ethernet.
What version of the Unifi network controller are you using to configure your UAP? It would show if a firmware update for your UAP is available. Also it would provide power supply information at your UAP.
- schumakuNov 16, 2022Guru - Experienced User
Very unlikely a normally and correct powered AP does loose a Gigabit Ethernet link at runtime to such a simple switch.
Much more likely the power supply using whatever nonstandard technology e.g. with some passive power-over-network-link.
Standard compliant IEEE 802.3af PoE, 802.3at PoE+ and 803.3bt PoE++ does in general work flawless over the 100 meters allowed Ethernet link length.
Solid contribution from schumaku . The POE injector that came with my AC-Pro is labeled Unifi but does not list any IEEE compliance standards for POE. It does list a voltage and current output.
If you have the opportunity to place the POE injector close to your UAP, feed it with the 30 m data cable and power, then connect a short 1 m cable to your UAP it might work. If not, it points back to your 30 m data cable as the culprit.
For long term use and reliability, a fully IEEE complaint POE switch is your best answer.
Did you install the end connections on the 30 m cable yourself? Are the end connections specifically identified for use with Cat 6 Ethernet cable?
