Bozack90
Dec 23, 2017Aspirant
Advice on what to buy - switch for home use
Hello I have moved into a new house where at each of the coax locations and in the home office is a Cat5e network drop, currently I have a total of 8 locations. I also have fios into the house. Lo...
- Dec 29, 2017
I just want to follow-up on this. Let us know if you have further questions.
Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
Bozack90
Dec 25, 2017Aspirant
Hey Dane,
Thanks, I am also thinking of model GS116A
They all seem very similar though, thanks
XavierLL
Dec 26, 2017NETGEAR Employee Retired
Hi Bozack,
In terms of the performance all models are quite similar . They are line-rate models with a non-blocking architecture so you can support 16 devices at 1Gbps with no bottleneck.
If you have a rack or a small cabinet the JGS516 it´s the perfect fit as it´s a rackmountable model. If you don´t have a rack and you just want to wall-mount the switch the GS316 and GS116 will work well as they are desktop/wall-mount switches.
Hope it helps!
Xavier Lleixa
NETGEAR CBU PLM
