WouterBiemans
Nov 05, 2017Aspirant
AirPrint does not work behind switch
Hi, AirPrint works in my home network as long as the GS105v5 switch is not in 'the chain'. I use the switch to connect to a laptop, a PC and the printer in the study to the home network. If I un...
- Nov 27, 2017Definitely not the switch. Switching off /on all inbetween units and t printer itself did the trick. Tnx for follow-up
DaneA
Nov 09, 2017NETGEAR Employee Retired
Hi WouterBiemans,
Welcome to the community! :)
As far as I have checked, there is no issue logged for the GS105v5 switch wherein AirPrint won't work as long as the GS105v5 is within the existing network as per described in your post.
Let us isolate the problem. Kindly answer the questions below:
a. While the GS105v5 switch is connected to your existing network, does your printer able to get a valid IP address when it is connected to the GS105v5 switch?
b. Is the GS105v5 switch connected to a router? How is everything connected? It would be best if you post an image or screenshot of your detailed network setup.
c. Have you tried to reboot the GS105v5 switch then try if you will be able to use AirPrint?
Not sure if this will help, however, let me share the articles below:
AirPrint® Software Feature Setup Using the genie App
DaneA
NETGEAR Community Team
