WouterBiemans
Nov 05, 2017Aspirant
AirPrint does not work behind switch
Hi, AirPrint works in my home network as long as the GS105v5 switch is not in 'the chain'. I use the switch to connect to a laptop, a PC and the printer in the study to the home network. If I un...
- Nov 27, 2017Definitely not the switch. Switching off /on all inbetween units and t printer itself did the trick. Tnx for follow-up
DaneA
Nov 12, 2017NETGEAR Employee Retired
I just want to follow-up on this. We’d greatly appreciate your feedback.
DaneA
NETGEAR Community Team
- WouterBiemansNov 20, 2017AspirantHi, first the printer worked when bypassing the netgear switch but also this solution was not consistent/sustainable. So my conclusion could only be it was NOT the netgear switch after all.
I cycled power to all involved switched, routers , airport express and the printer itself. The pronter shows up under airprint, Let’s see if it still works tomorrow...- DaneANov 27, 2017NETGEAR Employee Retired
- WouterBiemansNov 27, 2017AspirantDefinitely not the switch. Switching off /on all inbetween units and t printer itself did the trick. Tnx for follow-up
