WouterBiemans
Nov 05, 2017Aspirant
AirPrint does not work behind switch
Hi, AirPrint works in my home network as long as the GS105v5 switch is not in 'the chain'. I use the switch to connect to a laptop, a PC and the printer in the study to the home network. If I un...
- Nov 27, 2017Definitely not the switch. Switching off /on all inbetween units and t printer itself did the trick. Tnx for follow-up
DaneA
Nov 12, 2017NETGEAR Employee Retired
I just want to follow-up on this. We’d greatly appreciate your feedback.
DaneA
NETGEAR Community Team
WouterBiemans
Nov 20, 2017Aspirant
Hi, first the printer worked when bypassing the netgear switch but also this solution was not consistent/sustainable. So my conclusion could only be it was NOT the netgear switch after all.
I cycled power to all involved switched, routers , airport express and the printer itself. The pronter shows up under airprint, Let’s see if it still works tomorrow...
- DaneANov 27, 2017NETGEAR Employee Retired
- WouterBiemansNov 27, 2017AspirantDefinitely not the switch. Switching off /on all inbetween units and t printer itself did the trick. Tnx for follow-up
- DaneANov 28, 2017NETGEAR Employee Retired
Thanks for the update. I'm glad to know that the problem has been isolated and there is no problem with the GS105v5 switch. :)
Since the problem has been isolated and your concern got resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
