divenom
Apr 18, 2017Follower
Basic Switches (Cheapest ones) Are they Fail Open switches?
We know that Mac flooding was an old practice. Is it still common? I mean does these cheapest switches which are mostly used in SOHO startups in india vulerable to MAC flooding attack. or In simpl...
- Apr 19, 2017
Hi divenom,
Welcome to the community! :)
I've checked that there are no issues yet about MAC flodding on the FS208 switch. The FS208 switch is an unmanaged switch. Its main purpose is just to extend the local network if you need additional ports to connect more devices such as PCs, printers, etc.
A way to prevent MAC flooding is to configure Port Security. Port Security is a feature wherein you can lock one or more ports. When a port is locked, only packets with an allowable source MAC addresses can be forwarded and all other packets are discarded.
I recommend you the GS108Tv2 smart switch that supports Port Security. Kindly check its specifications on its data sheet here.
DaneA
NETGEAR Community Team
DaneA
Apr 23, 2017NETGEAR Employee Retired
I just want to follow-up on this. Let us know if you have further questions.
If ever your concern has been addressed / resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
