Hmcfly's avatar
Hmcfly
Can't get the lights to work on gs305 v3
I just bought a gs305 v3 and I plugged it in and ran a cable from my router and it lights up but when I plug in another cable I get no lights to come on any suggestions
  • schumaku's avatar
    schumaku
    Reads like a basic problem with that other cable of an Ethernet link can't be established.
    • Hmcfly's avatar
      Hmcfly
      Does that mean the switch is bad because it doesn't connect on the other end
      • schumaku's avatar
        schumaku
        If another cable does work as expected to establish a link between the switch and device like a computer or another switch - figure.
ProSupport for Business
