cdmiller
Jun 19, 2017Aspirant
Can't login from Prosafe 2.3.5 after 2.0.1.40 firmware update
Today I received a security alert from Netgear about older verions of Prosafe. So, I went online to check out my version. While I was on the latest version of Prosafe, I saw that I was not using th...
- Jun 20, 2017
HI cdmiller,
Could you let us know which switch model do you have ?
The latest ProSafe version that we have it's the 2.4.3 and you can download from :
https://kb.netgear.com/000037852/ProSAFE-Plus-Configuration-Utility-v2-4-3
Hope it helps!
Xavier Lleixa
NETGEAR CBU PLM
cdmiller
Jun 21, 2017Aspirant
Upgrading to Prosafe 2.4.3 resolved this problem. I should have tried that first. I can no login successfully from the utility. Thank you for your help.
XavierLL
Jun 21, 2017NETGEAR Employee Retired
thanks cdmiller to let us know :)
Enjoy your Plus Switches!
Regards
Xavier Lleixa
NETGEAR CBU PLM
