Firmware
6 TopicsGSS116E will not boot after upgrade from firmware version 1.0.0.2 to 1.0.0.5.
GSS116E will not boot after firmware upgrade from 1.0.0.2 to 1.0.0.5 after following upgrade instructions in the release notes. Upgrade from 1.0.0.0 to 1.0.0.2 and bootloader 1.0.0.5 was successful. All the LEDs stayed on after loading firmware 1.0.0.5. Reset button and power cycle has no effect. Is there a recovery method? Plus Click Switches (GSS116E) This is the second unit I upgraded. The first upgrade was successful to 1.6.1.7.912Views0likes1CommentTesting, Troubleshooting, Updating, Loving & Fixing. How do I do those things?
Setup/Problem 2nd paragraph (Short question what URL do I use to download drivers/bios or software for gs108v3 Win10x64 ProSAFE Plus Configuration Utility v2.4.9 not discovering switch) I have a Prosafe GS108v3. It has mostly been sitting unattended & forgotten about. My computer/internet have worked flawlessly for 2-3 years. Ive checked bios, drivers and integrity of every piece of hardware on my Win x 10 Build 1709 Rig/computer. I've reinstalled Win 10 2 weeks ago. It is 100% functional. The only thing I have not tested is this GS108v3. My boyfriend and I smoke, though he isn't here a lot. It has sat in a typical room on a standard computer, I want to check it (Does it have BIOS/Drivers?) Can I update it? Is there a general program to "test" it? I do not know much about it. My ATT Uverse (Arris Router/Modem) & a few other things are hoooked into it. So it sits in the middle of my computer and Arris router. I bought a new Arris router 6 days ago, it is 100% functional Problem: WINMTR/Traceroute and other programs say I "am losing data"/getting errors (My side, not ISP). I just want to do general maintance to my Gs108. It has been 3 years since I've touched it. I am unsure which programs to download (drivers, bios or tests). I am confused which program(s)/sofrware to download. I just want quick troubleshooting on this before buying a new one. TY! When I download: https://www.netgear.com/support/download/ (Prosafe) it is not recognizing/finding my switch.Solved4.3KViews0likes7CommentsCan't get out of loader mode for my CS105v2 switch. Is there a way out?
I went clicking around in my new switch to explore and see what configuration options I have, and I clicked on firmware update, and it took me to a page that asks for a TFTP Server IP Address and an image file name. I don't want to update this thing atm, nor do I want to have to reboot it. Is there anything I can do to get out of loader mode? Because it literally isn't letting me do anything else.Solved2.7KViews0likes2CommentsCan't login from Prosafe 2.3.5 after 2.0.1.40 firmware update
Today I received a security alert from Netgear about older verions of Prosafe. So, I went online to check out my version. While I was on the latest version of Prosafe, I saw that I was not using the latest firmware (2.0.1.40). I was using 2.0.1.26. So, I updated the firmware. Since doing so, I am not able to login using the Prosafe utility. I get the message "Login Command is not supported by agent!". I am able to login from Firefox using the switche's IP. After quite some time, I've powered off the switch in hopes I could login. But to no avail. Has anyone else had this problem? Any suggestions? Thanks, Chris.Solved5.4KViews0likes4Comments
