saidogoid
May 13, 2021Tutor
Can't reach netgear support
Hi all, I was upgrading my firmware, and after the reboot the switch just hangged with orangle light and does nothing. After some research, saw that the best option is to call a RMA. Tried to do ...
schumaku
May 14, 2021Guru - Experienced User
Not sure, the dial-in numbers could vary, depending on the location. Last option, it could be a call routing issue by Netgear's service provider.
Country you are calling from?
International prefix correct for your phone provider and location?
This issue requires more detailed investigation - it's not the first similar report these days.
saidogoid
May 14, 2021Tutor
Hey
So I,m on PT (We use +351) . Problem is, even if I put this indicator on the beggining of the number, it doen't work. So, I don't really know if the number have another preffix to use.
- JohnC_VMay 14, 2021NETGEAR Employee Retired
Please send us a private message with your contact information along with your case number so we can forward your concern to our support team for further review. .
Case number:
Name:
Email Address:
Contact Number:
Model Number:
Timezone:
Preferred time of callback:
We look forward to receiving your private message
John
NETGEAR Community Team
- saidogoidMay 24, 2021Tutor
Just giving some updates here:
After the last message, I gived my details and netgear called me and we solved the first time of the process. They diagnose, and asked me to sent back my faulty unit, and as soon they receive my unit, they will send a new one (same but v3) to replace it. Now waiting for the faulty reach theis facilities, so the process go on. Thank you very much for all your messages, Will update this topic as soon I have more news.- saidogoidJun 13, 2021Tutor
Update:
Everything was solved now. After I received the router, I have a ton to do, that's why it's been a while. So far, everything works great, it took 1 week until I received my new unit. Good work Netgear! You really keep your promisse with lifetime warranty.
Thanks all for your help
