LaurenA's avatar
LaurenA
Correct PS for GS108v4?
At my office there is a GS108v4 that was missing its power supply.  I scrounged around at the office and found what I thought was the right power supply for it.  But I haven't plugged it in yet.  In the mean time, I ordered another GS108v4.   The power supply that came with the newly-ordered GS108v4 has different specs than the other Netgear power supply.   Can someone tell me if the power supply that I located in the office is safe to use with the GS108v4?  Here the specs on both of them:
Power supply that came in the box with the newly-ordered GS108v4:
Netgear
AC-DC Adapter
P/N 332-10830-01
Input: 100-240V~50/60Hz 0.15A
Output: 12V  0.5A
Model AD2072F20
Type 007LF
Older power supply that I found at the office:
Netgear
AC-DC Adapter
Part No: PWR-002-004
Input: 120AVC 60Hz 24W
Output: 12VDC 1.2A
  • LaurenA,
    Welcome to the community! 🙂
    It is NOT safe.  The official specification of the power adapter for the GS108v4 is 12V at 0.5A DC input which matches the specifications of the power supply unit that came with your newly ordered GS108v4.  As reference, kindly check page 2 of the GS108v4 Installation Guide here.
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    LaurenA,
    DaneA
    • LaurenA's avatar
      LaurenA
      Thanks so much for your response.  I really appreciate it!
ProSupport for Business
