CoolDude181
Jan 27, 2021Follower
COV for GS105 switch
Hello,
Looking for a CoV or other sanitization documentation regarding your GS105 unmanaged switches. Is there some reason why these aren't all simply downloadable from your site at all times?
Thanks!
CoolDude181 wrote:Is there some reason why these aren't all simply downloadable from your site at all times?
Especially for the many unmanaged switches, network adapters, and other devices where disconnecting power and using Windex to clean before reuse is perfectly fine 8-)
- DaneANETGEAR Employee Retired
Welcome to the community! :)
The latest GS105 switch model is the GS105v5 (v = version). Kindly download the Certificate of Volatility of the GS105v5 on this link. Be reminded that the link will expire within 2-3 days.
If you were able to download the Certificate of Volatility of the GS105v5 and you have no further concerns, I encourage you to close this thread by marking the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
