rdhjr
Jun 12, 2019Follower
Daisy Chain GS108LP
Just a quick queston, is it possible to daisy chain two GS108LP? I am trying to spread the POE budget on 8 IP cameras so I dont max one switch out at night when the IR 's come on.
Thanks!
Bandwidth permitting, yes, why not. With eight PoE cameras and just eight port the usage seems to be a little bit restricted anyway. If eight ports are enough (for PoE[+] cameras and uplink, you might consider the GS108PP (PoE Budget: 123W) version which is coming with the bigger power supply. Alternate approach might be using one GS116LP (PoE Budget: 76W) or GS116PP (PoE Budget: 183W).
1 Reply
