DutchOven
Nov 11, 2023Aspirant
Deeper rack mount ears
Hello,
I have a customer with a GS324P switch and I need to be able to mount it a few inches deeper in their server rack. Does Netgear make rack ears that allow the switch to be mounted further back in the rack? Or is there a 3rd party option?
Thanks!
Peter
- schumakuGuru - Experienced UserUsual workaround to add around 2 cm or about one inch is mounting the ears just ob two screws to the side.
- DutchOvenAspirant
Thanks for the tip but I've already done that and unfortunately I need about 2" of clearance and that only gave me about 3/4". I was able to find some rack extenders online that I think will do the trick. Here's the link in case it helps someone in the future: https://www.amazon.com/LiyaTech-Rackmount-Recessed-Adapter-Black/dp/B09HGMVJCD
