LeMike
Jun 15, 2023Aspirant
Does GS308PP include a DHCP server ?
Hello NETGEAR Community, I want to connect several PoE-enabled devices to a network switch, and I got GS308PP recommended. Main Purpose: Surveillance IP PoE-enabled 4K cameras as "CCTV" solutio...
LeMike
Jun 16, 2023Aspirant
I want to connect several PoE-enabled devices to a network switch, and I got GC110P recommended.
* Main Purpose: Surveillance IP PoE-enabled 4K cameras as "CCTV" solution.
Therefore, the features I need for any network switch (at least) are:
1. IP addresses automatically provissioning (DHCP server embedded).
2. Gigabit speed.
3. PoE (I don't know how much max power is required)
** No VLANs, QoS are needed.
1. Does this model meet these requirements ?
2. What is the best recommendation for me on Network Switch (based on my need) ?
** I'm looking for just buying a single device that meets all the requirements as the most efficient cost solution; This means avoiding buying additional router.
Your advice is welcome.
LeMike
schumaku
Jun 17, 2023Guru - Experienced User
Again a no.
Same incomplete questions as before in https://community.netgear.com/t5/Unmanaged-Switches-Forum/Does-GS308PP-include-a-DHCP-server/m-p/2318083/highlight/true#M6329
