tigerwutz
Apr 23, 2016Aspirant
experiencing network interruptions with video streaming on JGS524E
I bought a new JGS524E to replace my existing DLink switch. Sadly to say that I am not convinced with the new switch as I am experiencing network interruptions with video streaming. Technically speak...
- Sep 16, 2016
Hi DaneA,
it has been a long time of testing a trial and error. Unfortunately all captures failed due to the overall file size with wireshare. However I could eliminate the problem occured with a simple but effective change in the network seetings of the source. I changed the mounted drive from CIFS to NFS... Not sure why it has worked with the older LAN switch before with CIFS. Anyhow - solved and happy!
DaneA
Jun 12, 2016NETGEAR Employee Retired
Hi tigerwutz,
Were you able to try to capture the packets again wherein the problem has occurred while the packet capture is going on?
DaneA
NETGEAR Community Team
tigerwutz
Sep 16, 2016Aspirant
Hi DaneA,
- DaneASep 18, 2016NETGEAR Employee Retired
Hi tigerwutz,
I really appreciate your update. I am glad that the problem is now solved. :)
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
