chudak
Nov 22, 2020Guide
Failed switch
I had NETGEAR 16-Port Gigabit Ethernet Unmanaged Switch (GS316) for 3 years. 3 days ago I found my devices in disarray and after power off and on this switch everything work fine for awhile. However...
DaneA
Nov 23, 2020NETGEAR Employee Retired
Kindly check the physical connections. Check if the ethernet cables connecting the GS316 to the networking devices are properly plugged-in to the respective ports. Also, check if the power adapter of the GS316 is properly plugged-in to the AC outlet.
If the same problem still occur, access the GS316 support page here then click on the Guided Assistance button. Follow the online instructions to process an online replacement.
DaneA
NETGEAR Community Team
