chudak
Nov 22, 2020Guide
Failed switch
I had NETGEAR 16-Port Gigabit Ethernet Unmanaged Switch (GS316) for 3 years. 3 days ago I found my devices in disarray and after power off and on this switch everything work fine for awhile. However...
Bluewater24x7
May 10, 2021Aspirant
I am having the same connectivity issues. No problems until I switched to XFinity. I have an XFinity modem and Orbi RBR950 wireless router. I have tried the GS316 from the XFinity modem and the Orbi router. Nothing seems to work. I have tested all the cables. Nothing through though GS316 works. All the devices work directly wired from the XFinity or Orbi devices. I have read the power saving feature may cause a problem. Is there a way to turn it off on the GS316?
- chudakMay 10, 2021Guide
I suspect that in my case the switch was not faulty
I have a usb-c hub that was poisoning my network - e.g. making it unresponsive
I've never seen anything like that before, but that what it was...
- schumakuMay 11, 2021Guru - Experienced User
chudak wrote:I suspect that in my case the switch was not faulty
The interesting question here is to which device/port this USB Ethernet port replicator is connected to. Technically, these USB port replicators are sending out a pause frame while there is no USB host connected. This pause frame is intended only for the direct peer (the device they connect to physically) - this peer must not further distribute that pause frame an further, because each other device (supporting the pause frame) will immediately also stop sending frames. It does not matter if this is an Ethernet switch, the provider router, a mesh system: Every system forwarding these frames to other peers requires a fix (unmanaged switches a replacement).
