DuursC
Jan 13, 2024Aspirant
FAN loud XS508M
Dear all, I hope I get some tips for my problem what I have and maybe many others. I bought a XS508M unmanaged switch, a nice one but I am in shock about the very very noisy fan inside. I like t...
DuursC
Jan 24, 2024Aspirant
Dear all,
Add question about when is the ventilator light in the XS 508M going to orange, at what conditions?
I work with a Noctua fan is working pretty good but the light is orange.
I wander is that the RPM minimum value? or else? I dont think there is a blow CFM senor
Thx.
schumaku
Jan 24, 2024Guru - Experienced User
Non-compatible tach signal, or RPM lower than specified. Note. The higher the propeller tip speed is, the higher the noise level. It's not difficult to design fans with low noise: Just lower the RPM, or power them off.
