Marynel's avatar
Marynel
NETGEAR Employee Retired
Aug 06, 2018
Flexible PoE Switch with Power Upgrade Options - Blog
Do you need PoE In your Business?
What is PoE, you ask? Well, it stands for Power-Over-Ethernet, which means that just by using one Ethernet cable, you can supply both the network connectivity AND the power to run the PD (powered device). What this means for PoE-enabled devices like wireless access points, IP cameras, security door locks, etc, is that you won’t need to have a separate power supply and outlet nearby to install those devices; just run an Ethernet cable to them from a PoE switch, and you’re done!
Read more about PoE on the NETGEAR Blog:
Update Feb/5/2019:  The Extended range of upgradable power adapters for the Unmanaged PoE Switches - GS108LP GS108PP GS116LP and GS116PP are now available. Learn more about PoE from our Power over Ethernet Page.
To purchase the new PoE power adapters please click the model numbers below.
EPS90W
Compatible with
EPS130W
Compatible with
EPS200W
Compatible with
GS108LP
GS108LP
GS108PP
GS108PP
GS116LP
GS116LP
GS116LP
GS116PP
GS116PP
GS116PP
  • Update Feb/5/2019:  The Extended range of upgradable power adapters for the Unmanaged PoE Switches - GS108LP GS108PP GS116LP and GS116PP are now available. Learn more about PoE from our Power over Ethernet Page.
    EPS90W
    Compatible with
    EPS130W
    Compatible with
    EPS200W
    Compatible with
    GS108LP
    GS108LP
    GS108PP
    GS108PP
    GS116LP
    GS116LP
    GS116LP
    GS116PP
    GS116PP
    GS116PP
1 Reply
  • BretD's avatar
    BretD
    Administrator
    EPS90W
    Compatible with
    EPS130W
    Compatible with
    EPS200W
    Compatible with
    GS108LP
    GS108LP
    GS108PP
    GS108PP
    GS116LP
    GS116LP
    GS116LP
    GS116PP
    GS116PP
    GS116PP
ProSupport for Business
