jpm1
Mar 09, 2016Aspirant
FS116 - does it have network information?
does the FS116 have netowrk data available?
Hello jpm1,
Welcome to the community!
The FS116 is an unmanaged switch with no software/firmware to manage it. I don't believe that you can pull out any network data of off it since it is just pure hardware.
Let us know if you have more questions.
Thanks,
- JohnRoNETGEAR Employee Retired
Hello jpm1,
Thanks,
- jpm1Aspirant
thank you very much!
another question for the same switch, could you guess what might happen if someone plugged a PoE (power over ethernet) device into this switch?
- DaneANETGEAR Employee Retired
Hi jpm1,
The FS116 switch does not support PoE. Thus, its not a PSE or Power Sourcing Equipment. If you will connect a PD or Powered Device (a device that will turn on via PoE) to the FS116 switch, it will not power up. What you need is an FS116P switch because it supports PoE. For more information about FS116P switch, kindly click on the link below:
http://support.netgear.com/product/FS116P
DaneA
NETGEAR Community Team
