ghamer3545's avatar
ghamer3545
FVS338 ProSafe as an unmanaged switch
I have an FVS338 ProSafe VPN Firewall 50 that is no longer in use.  I could use an unmanaged switch in my home network.  Is it possible to use the FVS338 as an unmanaged switch.  If so do I need to d...
  • DaneA's avatar
    DaneA
    May 19, 2021
    ghamer3545,
    Just to add, it would be best if you set a static IP Address on your FVS338 that is within the IP Address range of your existing network then proceed with the  disabling the DHCP Server.  This is for you to still gain access on the web-GUI of the FVS388.
    DaneA
    NETGEAR Community Team
ProSupport for Business
