bergpr
May 10, 2021Aspirant
gateway addres 169.254.29.193 instead 192.1681.1.
I attached my new GS108 switch but it connects to 169.254.29.193 on my ASUS gateway, instead of the correct address 192.168.1.1. How di i change this into the right address? Peter
- May 23, 2021I solved it by setting the gateway at 192.168.1.1 in the network adapter ip-settings, under Advanced.
Success.
schumaku
May 10, 2021Guru - Experienced User
The GS108 is a unmanaged switch. Even the more expensive configurable or smart manageable don't make use of Zeroconf addresses like 168.254.x.x/16 - and it's IP is only for local management purposes, and not for routing.
If a system connected through such a switch to the router - assuming the port on the router/gateway where it's connected is working - and there is no DHCP server available, no MAC address reserved or allowed to access the router, (and obvious without a static/fixed IP configured).. many modern OS fall back to Zeroconf addresses. This is not something assigned by either the switch or a router.
Start with checking the link speed negotiated - check if the LEDs on the switch, computer port, and router show an active and assumable working link.
tayder
May 23, 2021Aspirant
i am having the same issue only mine gets registered as 169.254.166.188 all lights green and ports plugged in securely router reset several times switch reset several times wont give internet connction or local networking due to mis configured IP. how do i fix this? or do i just return it for something else?
- bergprMay 23, 2021AspirantI solved it by setting the gateway at 192.168.1.1 in the network adapter ip-settings, under Advanced.
Success.- tayderMay 23, 2021Aspirant
it wont alow me to set that as a gateway but i can set the dns but it still wont resolve a "valid" IP
**edit** dns is configured to the original networks dns 192.168.0.1- tayderMay 24, 2021Aspirant
it seems could be an issue with the network card on the desk top i was trying to network it no longer works with a strait line either anymore but i plugged a few linux computers into the switch after strait cable didnt work and it gave them full network and internet access. thank you for the assistance but it seems the problem is on my end
