zvonko
Jan 23, 2021Follower
GS105 AC adapter
Hi, Two years ago I bought five GS105 switches and I did not open the boxes until a few days ago. My house was still not built so I did not need these switches until now when I decided to finish in...
schumaku
Jan 25, 2021Guru - Experienced User
zvonko wrote:Two years ago I bought five GS105 switches
Do you remember where you have bought these switches from?
zvonko wrote:When I opened all five boxes I can see that there is no AC adapter at all! There is only one short cable with a circuit switch in the middle and connectors on both ends, one 5mm diameter connector for switch side and one ERNI connector for AC adapter
Looks to me like these are switches for a specific OEM for whatever deployment or system integration, not intended for retail sales. Please provide more details like exact model designation from the switch product label and from the box. if unclear, add two photos please.
Typical designators are:
GS108-x00NAS North America and Latin America
GS108GE GS108-x00EUS Europe
GS108AU GSx00-x00??? Australia
GS108UK GS108-x00UKS United Kingdom
GS108-x00JPS Japan
Note the switch can have a different designator (as the switch might be the same for many markets, while the box will show a market specific ordering number like GS108-x00yyy ... the "x" is a hardware version number, "00" a normal market device, and "yyy" does indicate the region or country.
I would try to complain with the original seller - even it it proofs to be difficult after two years.
Just in case, replacement power supplies are available in the market.
