jt_manhattan's avatar
jt_manhattan
Orbi AC Adapter Replacement
I purchased an Orbi system on Amazon.  Everything seems to work fine except that one of the AC Adapters is broken.  When I switch the adapters the router and satellite work fine.  I can only assuem that the broken adapter doesn't provide consistent power.  Is there a place I can purchase a replacement adapter?  Or if someone knows a quick fix that would be much appreciated.
Ji Yeong Kim
  • Should be under warranty, no?  Contact Netgear support.
