winc
Jan 03, 2023Guide
GS105 and passing IP address
I have three VoIP phones connected to a G105. The GS105 subsequently goes to another (larger) unmanaged switch with hands out DHCP addresses from my Sonicwall firewall. Occasionally the three Vo...
Jan 03, 2023Guru - Experienced User
I would wonder if theres a green features on your smart switch.
The GS105 is a simple unmanaged switch so it doesn't manage anything.
So potentially the smart switch its connected to is disabling the connection and not re-enabling it for some reason unless the gs105 is rebooted. I'd be looking closer at the managed switch
- wincJan 04, 2023Guide
Thanks plemans. There is no managed switch in the picture. Traffic goes from GS105 > unmanaged HP 24-port switch > Sonicwall > carrier-provided Network Interface Device.
- plemansJan 04, 2023Guru - Experienced User
Got a long cable sitting around you can connect the gs105 directly to the sonic wall to test it?
- wincJan 05, 2023Guide
Thanks plemans. One problem will be getting the trouble to reoccur. Since the GS105 is fairly cheap and running a longer cable will be a PITA, I am thinking about replacing the GS first.
