UnlivedOyster
Dec 11, 2022Aspirant
GS105 and wifi
I need some help and I am not sure where to go. I have a windows 10 machine connected to a wifi router from verizon. The pc also has a unused ethernet port. I also have: A Netgear GS105 swit...
- Dec 12, 2022
UnlivedOyster wrote:
I guess what I need is help getting the windows 10 configured to work with both of its adapters.
The key is to design and implement one network. A network cable or a fiber would allow to establish a nice connection.
schumaku
Dec 12, 2022Guru - Experienced User
https://www.verizon.com/support/residential/internet/equipment/routers a little bit vague. Most of these come with at least one LAN (Ethernet) port, allowing to connect one or multiple LAN Devices, like your PC LAN port, like your Synology NAS LAN port, and probably like your 3D printer if equipped with a LAN port.
The Windows computer does get a LAN config from the router DHCP server, assigning IP address and so on. Same applies to the Syno NAS, .. and so on. Everything will be connected to the network (LAN), the wireless is not require because everything is wired. If more network (LAN, Ethernet) ports are required, your Netgear GS1xx does have more ports and can be used to cascade the connections.
- UnlivedOysterDec 12, 2022Aspirant
Except that the router is not in the same room as the rest of my equipment and can not be moved, not even the same floor of the house.
thanks for trying.
- schumakuDec 12, 2022Guru - Experienced User
