j0kky
Dec 03, 2015Aspirant
GS105, GS205, GS305 or GS605?
Hi guys, I need a GigaBit switch for my home network, maybe I will insert the switch into the wall (in a sort of box). I see the site suggests me to buy GS205 or GS605, but what is the difference o...
- Dec 03, 2015So I'll go for GS305.
Thank you for your help!
JohnRo
Dec 03, 2015NETGEAR Employee Retired
Hello j0kky,
Welcome to the community!
The switches mentioned have the same functionality since they are all gigabit switches. They differ though in enclosures used, plastic for 200 series (GS205) and metal for 300 series (GS305). They pretty much have the same standards so any of the switches should work. The GS605 model is EOL(End of life) and the GS105 is an old model so I might consider getting the 205 or the 305 instead. If you want to know more about the switches and their differences please click on the following links: 200 Series Switches, 300 Series Switches.
Let us know if you have more questions.
Thanks,
