rickcandle87's avatar
rickcandle87
GS205 vs. GS605
How do I decide what the difference between these two switchwes are?
As far as I can tell from the website literature, the difference seems to be in the warranty as opposed to performance.  Am I correct or is there some other factor that recommends one over the other?
It also seems that the 605 is not in the retail pipeline as yet.
  • Hi all,
    There is a few extra differences on the design and the warranty , see the table below :
    Regards
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi rickcandle87,
    Welcome to the community! :)
    There seems to be a little difference on these two switches.  As far as I know, the GS200 switch series is newer than the GS600 switch series.  The GS205v2 and the GS605v5 are the latest models. Here below are the differences between the GS205v2 and GS605v5:
    For more information about these two switches, kindly access the links below:
    GS205v2 technical specifications
    GS605v5 technical specifications
    DaneA
    NETGEAR Community Team
    • XavierLL's avatar
      XavierLL
      Hi all,
      Regards
  • DaneA's avatar
    DaneA
    rickcandle87,
    I just want to follow-up on this.  Let us know if you have further questions.
    Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    DaneA
ProSupport for Business
