rickcandle87
May 07, 2017Aspirant
GS205 vs. GS605
How do I decide what the difference between these two switchwes are? As far as I can tell from the website literature, the difference seems to be in the warranty as opposed to performance. Am I c...
- May 08, 2017
Hi all,
There is a few extra differences on the design and the warranty , see the table below :
Regards
DaneA
May 08, 2017NETGEAR Employee Retired
Hi rickcandle87,
Welcome to the community! :)
There seems to be a little difference on these two switches. As far as I know, the GS200 switch series is newer than the GS600 switch series. The GS205v2 and the GS605v5 are the latest models. Here below are the differences between the GS205v2 and GS605v5:
For more information about these two switches, kindly access the links below:
GS205v2 technical specifications
GS605v5 technical specifications
DaneA
NETGEAR Community Team
XavierLL
Hi all,
Regards
