rickcandle87
May 07, 2017Aspirant
GS205 vs. GS605
How do I decide what the difference between these two switchwes are? As far as I can tell from the website literature, the difference seems to be in the warranty as opposed to performance. Am I c...
- May 08, 2017
Hi all,
There is a few extra differences on the design and the warranty , see the table below :
Regards
DaneA
May 11, 2017NETGEAR Employee Retired
I just want to follow-up on this. Let us know if you have further questions.
Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
