JeronimoB's avatar
Jan 03, 2023
GS105 Unmanaged assigning 192.254.106.x
Hi, I have a simple setup at home Modem/router (DHCP) --> straight-cable --> GS105 --> patch cable --> AppleTV        --> PS4 When I co...
  • plemans's avatar
    Jan 03, 2023
    Cable testers are a gray area. I've had cables test out perfectly fine using one but not work when tested between devices. Unless you have a pretty high end tester, they just pass a current down the line. If the receiver picks it up, its good. But sometimes sketchy connections are good enough for current but not data transfer. So try different cables.
    Try bringing the apple tv and the switch right next to the router and use 2x 6ft cables to connect them. That ensures its nothing in the walls, the patch panel, or those cables causing issues.
ProSupport for Business
