JeronimoB
Jan 03, 2023Tutor
GS105 Unmanaged assigning 192.254.106.x
Hi, I have a simple setup at home Modem/router (DHCP) --> straight-cable --> GS105 --> patch cable --> AppleTV --> PS4 When I co...
- Jan 03, 2023
Cable testers are a gray area. I've had cables test out perfectly fine using one but not work when tested between devices. Unless you have a pretty high end tester, they just pass a current down the line. If the receiver picks it up, its good. But sometimes sketchy connections are good enough for current but not data transfer. So try different cables.
Try bringing the apple tv and the switch right next to the router and use 2x 6ft cables to connect them. That ensures its nothing in the walls, the patch panel, or those cables causing issues.
JeronimoB
Jan 03, 2023Tutor
plemans I checked the patch cables with my cable tester and tested the patch cable directly on my router with my laptop connected. Weird thing.
The GS105 does not care about cross-link or straight-through (that was one concern I had). Maybe truly a faulty GS105 somehow...
Jan 03, 2023Guru - Experienced User
- JeronimoBJan 03, 2023Tutor
So.... although the straight-through cable from router to switch (approx 20m length) was working technically fine with the AppleTV I decided to connect two new RJ45 connectors. It appeared the wiring was not correct (although all pins were straight-through connected, it was not White/Orange - Orange - White Green - Blue - White Blue - Green - White Brown - Brown). I think due to length of cable, this might have caused the issue. Indeed; do not trust the cable tester blindly đ
- plemansJan 03, 2023Guru - Experienced User
Glad you got it working!
