PTAa
Jan 17, 2023Aspirant
GS105 v3 issue
Hello group,
My GS105 v3 switch behaves oddly.
The switch has three connections:
- Port1: 1000 M cable to the fiber router with Internet and IPTV subscription
- Port2: 1000 M cable to the IPTV STB
- Port3: 10 M Remoterig RRC-1258 MkII controller for remote radio
Whenever the Port3 device is off, all works just fine with the TV.
But when I activate the RRC, both the TV signal and the remote radio stalls.
The Ethernet interface on the RRC-1258 can be changed to 100 M.
When I do that, all works fine.
Why can't the GS105 handle an active port with a 10 M signal?
For some reason, it looks like the total bandwidth is reduced so much that the TV signal stalls.
Does the problem travel if you use the other ports?
Possible that this device maybe inducing some odd signals.
Try a different switch to see if the problem follows or not.
- PTAaAspirant
Same for all ports.
I also tried it with my FS105 v2, same results.
But the WiFi Plus access point from the IPTV provider handles it well.
Apparently, it does not happen so much when I use a streaming channel.
If it is real-time channel, it is bad.
If I select the Open LogFire channel, is breaks down completely.
That channel has a lot of motion in the picture due to the flames, so the traffic is high.
P-T
- PTAaAspirant
No ideas?
P-T
this sounds like a bug or a big oversight in the QA process....
