kbrunke's avatar
kbrunke
Follower
Mar 02, 2021
GS105 with Google Wifi
I have an existing wifi (Google Mesh) running from my Cox Cable Modem.  I want to run a direct ethernet connection to one of my computers so I bought the GS105 switch.  So my setup is Cox Cable to ca...
  • schumaku's avatar
    Mar 04, 2021
    kbrunke wrote:
    So my setup is Cox Cable to cable modem, ethernet cable from modem to Netgear, then from Netgear I ran (1) ethernet cable to Google wifi and (1) ethernet directly to computer.
    You can't do this - the modem must be connected direct to the Google WiFi WAN/Internet port (this is the one with the "earth" icon). This is the "outside" network where you typically just get a single public IP address. The switch must connect on the Google Mesh router LAN side (this is the one with the <...> icon).
    Needless to say .... to connect a single PC to the Google WiFi router,  there is no switch required.
    FMI: Add LAN ports to Google Nest Wifi or Google Wifi
    Not a Netgear switch problem at all.
ProSupport for Business
