othni's avatar
othni
GS105e can not login or factory reset
I have a couple GS105E switches at work. I am using the latest ProSafe Utility version 2.3.20 to access them. The switches show up in the utility, but do not accept any password (or blank) to c...
  • ElaineP's avatar
    ElaineP
    Nov 11, 2016
    Hi othni
    We get the information: FW v3.01.28 is an official release for TOTALPLAY, which is customized product.
    The default setting difference was requested from TOTALPLAY, so TOTALPLAY should know the default password is not “password”.
    Please contact Totalplay directly because of only Totalplay know the password.   :smileyhappy:
    Thanks for JohnRo’s help, too.
    NETGEAR Employee
ProSupport for Business
